Is language french supported?
Optiplan
Post by Optiplan »
I selected French in the "Select Language" panel. I tried French because I have a problem with my file names with accent as (é à ...).
As an example, a file or a directory name is invalid in Paper even if the interface is French. I still have to give english name for files , forders, Tags, Labels.
I dont mind using english UI, but being able to use french with my file names is important in exchanging files with french people.
Thanks for your support.
XYplorer is a great product
Re: Is language french supported?
Post by Horst »
How did you create the Paper folder ?
Its encoding should be UTF-16 LE with BOM.
With this there should be no problem to display french names.
Just tested this. No problem here. :?
