Searching for files with a choice of content
Posted: 15 May 2008 13:57
by TadgerMonkey
How do you/can you search files looking for a choice of content?
I want to be able to find files that contain either FBloggs or the IP address 10.0.1.1 or the machine name MyPC.
Re: Searching for files with a choice of content
Posted: 15 May 2008 14:31
You cannot. Boolean operations are not supported in content search at the moment.
Posted: 15 May 2008 16:28
by eurytos
depending on the filetype, notepad++ can search files/directories for strings etc. That may work.
Posted: 15 May 2008 18:04
by TadgerMonkey
eurytos wrote:depending on the filetype, notepad++ can search files/directories for strings etc. That may work.
Of course! I hadn't thought of that...it's not exactly what I'm after, but it'll do for now.
Thanks again. :D
