Can the script copy or move files to the specified folder
Kenbol
Post by Kenbol »
Can the script copy or move files to the specified folder,include newly created path,just like CMD in Windows
Re: Can the script copy or move files to the specified folder
Kenbol
Post by Kenbol »
Isn't it this type?ok
Post by Horst »
Sorry, but no one can understand what you are talking about.
Which script ?
What function of cmd ?
Try to explain with examples
Windows 11 Home, Version 26H2 (OS Build 26300.9711)
Everything 1.5.0.1424b (x64), Everything Toolbar 3.5, Listary Pro 7.1.0.45 beta
Kenbol
Post by Kenbol »
xcopy /y "D:\Dt\modular.ps" "F:\Data\Ten\sample\210825\"
Copy the file modular.ps to path "F:\Data\Ten\sample\210825\"
Disk F does not have this path "F:\Data\Ten\sample\210825\",create this path,and then copy or move the files
Both script commands copyto and moveto have the flags=2 parameter to automatically create non-existent paths...
Kenbol
Post by Kenbol »
I checked the documentation and didn't see how to run multiple script commands
rtfm "idh_scripting.htm#idh_scripting_multi";
Kenbol
Post by Kenbol »
Thx for reply
The multiline script command did not run successfully...
The very first paragraph...
In a multi-line script all lines apart from the first line have to be indented by at least one space.
1024mb
Post by 1024mb »
The patience of a saint
