Column header text color
Posted: 19 Sep 2019 12:47
by AugerJ
Hi. How do I change the column header text color? (The text would be: "Name", "Size", "Modified" etc.)
Is it linked to some other color?
Thanks.
Re: Column header text color
Posted: 19 Sep 2019 13:06
by jupe
    + List: Added tweak to customize the colors of the column headers. Specify
      the color in RRGGBB|RRGGBB format (backcolor|textcolor), e.g.:
        ListColumnHeaderColors=BFDAFE|223344
      You can omit the text color to have it auto-generated by artificial
      intelligence. Note that in Dark Mode your colors will be smart-darkened.
for instructions on how to tweak: https://www.xyplorer.com/faq-topic.php?id=tweak
Posted: 19 Sep 2019 13:43
by AugerJ
Thanks.
