type stats and filter CTRL and Shift click on <DIR>
Posted: 31 Jul 2017 13:09
by NS-Zero
When hold ctrl and click <DIR> at type stats and filter list, it select all files instead of select all folder.
When hold shift and click <DIR> it remove all files from the selection.
Bug or not?
Re: type stats and filter CTRL and Shift click on <DIR>
Posted: 31 Jul 2017 13:23
Bug indeed, thanks! :tup: (Fix comes)
