When hold ctrl and click <DIR> at type stats and filter list, it select all files instead of select all folder.
When hold shift and click <DIR> it remove all files from the selection.
Bug or not?
type stats and filter CTRL and Shift click on <DIR>
Re: type stats and filter CTRL and Shift click on <DIR>
Bug indeed, thanks!
(Fix comes)
