Will not set as default file manager
READ THIS AND DO IT!!!
https://www.xyplorer.com/faq-topic.php?id=dfm
Yes I have seen this and that is what I have tried, and this worked with previous version.
I've installed 19.3, and it is refusing to set as default file manager.
Tried as administrator and setting for all users, and also as regular user, setting just for current user. Tried rebooting and doing it all again.
Even tried setting compatibility mode to Windows 7.
Windows 10 Enterprise, Version 1803
Re: Will not set as default file manager
You could check these registry keys manually, to see if XY is setting them correctly.
HKEY_CURRENT_USER\Software\Classes\Directory\Shell
HKEY_CURRENT_USER\Software\Classes\Drive\Shell
Do they contain the XYPlorer sub keys, and if so are the paths correct?
Yes, set correctly in both.
I'll try uninstalling and re-installing. Perhaps that will help.
It's partly working...
Dropbox selecting open folder brings up XYplorer, as does creating a new directory on desktop and double clicking it.
From OneDrive, open folder brings up Windows Explorer, Lightroom right clicking an image and selecting show location opens WIndows Explorer, and so does 'Windows Key'+E.
Probably hardcoded, not taking the registry settings into accountFrom OneDrive, open folder brings up Windows Explorer, Lightroom right clicking an image and selecting show location opens WIndows Explorer
This has nothing to do with registering something as the default filemanagerWindows Key+E
If you want to change that, open a command prompt with admin privileges
Execute these commands (ofc you have to adapt the paths if you want to do it only for the current user and not for all and DON't forget to change this "<path to XYplorer>" to the real path of your XYplorer installation / portable folder!
REG COPY "HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Folder\shell\opennewwindow\command" "HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Folder\shell\opennewwindow\command.bak" /f
REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Folder\shell\opennewwindow\command" /v "DelegateExecute" /f
REG ADD "HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Folder\shell\opennewwindow\command" /ve /d "<path to XYplorer>\XYplorer.exe" /f
Wow, so there it is! Tried it manually and it works well. I renamed DelegateExecute to DelegateExecuteORIG, and added the XYplorer full path to the standard key. Voilà, Win+E opens XYplorer. Thanks, man!highend wrote: ↑04 Nov 2018 09:06This has nothing to do with registering something as the default filemanagerWindows Key+E
Execute these commands (ofc you have to adapt the paths if you want to do it only for the current user and not for all and DON't forget to change this "<path to XYplorer>" to the real path of your XYplorer installation / portable folder!Code: Select all
REG COPY "HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Folder\shell\opennewwindow\command" "HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Folder\shell\opennewwindow\command.bak" /f REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Folder\shell\opennewwindow\command" /v "DelegateExecute" /f REG ADD "HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Folder\shell\opennewwindow\command" /ve /d "<path to XYplorer>\XYplorer.exe" /f
PS: Even when you click on the Explorer icon it will open XYplorer now!
- XYplorer-Win+E.png (11.52 KiB) Viewed 5570 times
mariovalerio
Hello,
in my case xyplorer doesn't set as default file manager. Every time I restart, the hook in the option "set xyplorer as default manager" is away and windows explorer is again the default file manager.
Can you please help?
Post the content of the default value for:
AFTER starting XY and setting the
"XYplorer is default file manager"
checkmark...
[HKEY_CURRENT_USER\Software\Classes\Directory\Shell\XYplorer\Command]
[HKEY_CURRENT_USER\Software\Classes\Drive\Shell\XYplorer\Command]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Directory\Shell\XYplorer\Command]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Drive\Shell\XYplorer\Command]"XYplorer is default file manager"
checkmark...
mariovalerio
I have also reinstalled XYplorer and then checked the keys in the registry: everything looks ok, but the hook to set XYplorer as default in the Configuration window disappears every time I restart; XYplorer is then replaced from the Windows explorer.
I have tried many times... can you please help?
highend might be able to help you once you answered his questions above...
Ralph
mariovalerio
sorry, I did not understand that it was a question, but a statement.
In all four keys the value is:
"C:\Program Files (x86)\XYplorer\XYplorer.exe" "%1"
The quotes are included in the key values.
Restarting = Windows reboot or a restart of XYplorer (without a Windows reboot)?
What are the default values for:
While
1. XY is running (and the "XYplorer is default file manager" checkmark is set)
2. After a "restart"
Additionally, which XY version are you using exactly?
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Directory\Shell1. XY is running (and the "XYplorer is default file manager" checkmark is set)
mariovalerio
Thank you for your help!
restarting = rebooting
After XYplorer is set as default (checkmark in the configuration):
key value is: XYplorer
after Windows rebooting:
key value is: none
I am using the latest version of XYplorer 19.40.0100
key value is: none
The scope for the integration you're using is: Only for the current user, right?
You've used (at least once): For all users of this computer, otherwise HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Directory\Shell
wouldn't be populated with "XYplorer"
So, "<something>" on your computer resets the setting for the current user. This is NOT XYplorer doing it!
There is something else running in the background (probably only on system restart) that does it...
mariovalerio
Yes, it happens only for "only for this user".
I have set XYplorer as default for all users too, but I am actually the only user on my computer.
I will set off the running apps on restart one by one to see if one of them causes this. It will take some time.
Will come back asap.
Thank you so much for now!
