Here's the new BETA (32-bit)
Get a glimpse of the next XYplorer...
Locked
Re: Here's the new BETA (32-bit)
Change Log for the latest XYplorer BETA version (32-bit):
v27.10.0401 - 2025-08-10 12:11
    + New Constant: <cr> is resolved to the Carriage Return byte (0D).
    + New Constant: <lf> is resolved to the Line Feed byte (0A).
    > Constants <cr> and <lf> take an optional count parameter for repetition. Example:
        echo "Catch<lf 22>22";
    * Percentage: In various contexts, such as the "Reduced to" dimensions in the Hover
      Box, ratios from 0.995 to 0.999 were rounded up and shown as 100%. Not good. Now,
      those values are rounded down to 0.99 and shown as 99%.
:info: To easily upgrade to this BETA version of XYplorer (32-bit), hold down the CTRL key and click Help | Online Support | Check for Updates. If you prefer to download the BETA version, choose one of these packages:
(1) Installer Package, (2) No-Install Package (for manual unpacking).
:!!: Note that BETA versions are work in progress and may contain new bugs. You have been warned. It's a good idea to backup your complete XYplorer settings (File | Settings Special | Backup Application Data Folder...) before running a new BETA. This will also help to fix any new bugs.
v27.10.0402 - 2025-08-11 12:49
    + Floating Preview: Added a way to auto-position the viewer at the end of a previewed
      text file. Currently implemented as a tweak:
        FPTextTail=1
    % Thumbnails: Experimentally implemented a little speed boost for non-cached
      thumbnails. Exponentially more noticeable the more thumbnails there are.
v27.10.0403 - 2025-08-12 10:10
    + Floating Preview: Added toggle "Auto-Scroll to End" (Ctrl+E). Enable it to
      automatically position the viewer at the end of a previewed text file. This can be
      useful e.g. when viewing log files.
      The toggle is available in the context menu of the Floating Preview status bar
      (which can be toggled by pressing S). The Ctrl+E keyboard shortcut is always
      available (independently of the status bar and of the previewed file type), but of
      course it only affects previewed texts.
      FYI, this raises tweak FPTextTail to the UI.
v27.10.0404 - 2025-08-13 13:55
    + New Variable <xybitness n>: Returns "32" or "64" depending on the bitness of
      the main executable (XYplorer.exe).
        echo <xybitness n>; //"32" in the VB version, "64" in the TB version
    * Thumbnail Creation: The status bar now displays all items for which a thumbnail is
      being created. Previously, some items were omitted. If there's a hang, you can now
      see which item is causing it.
    * Info Panel | Raw View: Renamed the "Tail" toggle to "Auto-Scroll to End".
v27.10.0405 - 2025-08-13 20:42
    + Configuration | General | Sort and Rename | Sort: Added option "Treat hyphens and
      apostrophes like normal characters".
      Background: Unless it's a binary comparison, Windows's string comparison treats
      hyphens and apostrophes in a special way that might not produce the desired sort
      order. Now you are in control. For example:
        Not ticked:         Ticked:
          File.txt            File.txt
          File'A.txt          File'A.txt
          File-A.txt          File'C.txt
          FileB.txt           File-A.txt
          File'C.txt          File-C.txt
          File-C.txt          FileB.txt
      Remarks:
        - This setting only affects the Text and Natural sort methods.
        - And it only affects sorting in the main file list. Not in the folder tree and
          not anywhere else.
        - Ticking this setting will slow down sorting a tiny bit, so if you don't need it,
          don't tick it.
v27.10.0406 - 2025-08-14 10:31
    * MLS: Internally updated to version 8.197.
      > TRANSLATORS: Please wait until Reference_8.197.lng is uploaded.
        You will be notified if you have subscribed to this thread:
        https://www.xyplorer.com/xyfc/viewtopic.php?f=12&t=9648
    * Updated the help file.
    ! Configuration | Preview | Thumbnails | Show dimensions of original: The wrong
      dimensions were shown for certain image types (e.g., HEIC and AVIF). Fixed.
:off: Summary of the latest XYplorer Official Release (32-bit).
Download Page: https://www.xyplorer.com/download.php
v27.10.0500 - 2025-08-14 21:00
    = MAINTENANCE RELEASE.
  +++ Minor bug fixes and enhancements.
To easily upgrade to this OFFICIAL version from XYplorer, click Help | Online Support | Check for Updates. If you prefer to download this new version, choose one of these packages: (1) Installer Package, (2) No-Install Package (for manual unpacking).
v27.10.0501 - 2025-08-15 16:58
    ! Undo/Redo: After renaming a tagged folder, selecting Undo did not update the tags.
      Fixed.
v27.10.0502 - 2025-08-16 12:51
    + Custom Copy: When moving folders with contents to another volume (or to the same
      volume with "CustomMoveIntraFastFolder=0") there is a post-processing phase "Empty
      source folders are removed...".
      This phase used to freeze (with a nonresponsive progress dialog) on very large jobs
      (thousands of folders). But not anymore! Now, there is live progress feedback.
    * XYcopy: Updated to 2.10.0274.
    * SC filter: Since v7.90.0078 - 2009-01-27 21:16, the Visual Filter patterns used by
      this command have not been added to the Visual Filter Most Recently Used (MRU) list.
      However, this was inconsistent with the behavior of other comparable patterns, such
      as Live Filters and Ghost Filters. Therefore, the change was made so that the
      patterns are added to the MRU.
v27.10.0503 - 2025-08-17 16:19
    + Configuration | Jump to Setting: The settings list now also contains all bold
      subsection headings. Before, typing "Report" into the filter box yielded no results.
      It will now.
    ! Tree: In the Mini Tree, Ctrl+Down/Up did not always work properly to go to the next
      or previous sibling. Fixed.
v27.10.0600 - 2025-08-20 18:00
v27.10.0601 - 2025-08-22 17:05
    + Help | Online Support: Added command "Update to 64-bit Version". Click it to update
      your current 32-bit XYplorer instance to the latest official 64-bit version of
      XYplorer. There is a prompt before the actual update happens.
      If an official version is not yet available (i.e. currently), you will be prompted
      to update to the latest 64-bit beta version.
    - Help | Online Support | What's New?: Removed.
    * MLS: Internally updated to version 8.198.
      > TRANSLATORS: Please wait until Reference_8.198.lng is uploaded.
    + SC conf enhanced: Added setting "ShowIconOverlays" to control "Configuration |
      General | Refresh, Icons, History | Icons | Show icon overlays" programmatically.
      Examples:
        echo conf("ShowIconOverlays");  //get (value is also shown in status bar)
        conf("ShowIconOverlays");       //get (value is shown in status bar)
        conf("ShowIconOverlays", 1);    //set
        conf("ShowIconOverlays", 0);    //unset
        conf("ShowIconOverlays", 0, 1); //toggle 0/1
        conf("ShowIconOverlays", "");   //toggle 0/1, alt syntax
v27.10.0602 - 2025-08-23 12:36
    + Scripting got a new function.
      Action: Adds an item to an MRU list and returns the last used item from the list.
      Syntax: mru(type, [add])
        type: Type of list.
          vf: Visual Filters (currently this is the only supported list)
        add: [optional] Item to add to the top of the list (= last used).
             If missing or empty, the current list is not altered.
        return: Last used item from the list (before adding the "add" item).
      Examples:
        echo mru("vf"); //show the last used Visual Filter
        mru("vf", "*.txt"); //set "*.txt" as last used Visual Filter
    * SC filter: Removed the change from v27.10.0502 - 2025-08-16 12:51. Setting Visual
      Filters with SC filter will not update the Visual Filter MRU list anymore, just like
      it was all the time since v7.90.0078 - 2009-01-27 21:16.
      If you want your scripted filter in the MRU list, you now can use SC mru (see above).
v27.10.0603 - 2025-08-25 14:27
    ! Configuration | Colors and Styles | Highlights & Dark Mode | Selections: On
      "XYplorer Style (Rounded)" the focus rect (when set to Solid) was not drawn rounded
      when Full Row Select was enabled. Fixed.
    ! XYplorer Style (Rounded): Various other fixes and improvements concerning
      selections, focus rect, and hover effect.
v27.10.0604 - 2025-08-26 14:47
    % Load Times: Improved the granularity to better focus on the slow parts.
    ! XYplorer Style (Rounded): Hover effect was always 100% rounded in Full Row Select
      mode (since v27.10.0603). Fixed.
Locked
