Dragging from Firefox address bar (or tab)
Posted: 10 Jun 2006 01:34
by pissant
I've long had a habit of dragging-and-dropping from the Firefox address bar (or tab) to Explorer windows, in order to create .URL files that point to the current URL.
But when I drag onto XYplorer 5.00.0019, I get an error stating "Can't drop text".
I thought I had dragged from Firefox to XYplorer before, but maybe not... And I know this may not be a "bug" in the real sense. But in any case, can this be made to behave like Explorer?
Re: Dragging from Firefox address bar (or tab)
Posted: 10 Jun 2006 08:31
Yep, a cute little interaction trick that's missing from XY. I added it and it works smoothly. 8)
Only one thing I wasn't able to do: somehow Explorer senses the document title of the web page and uses it as file name for the internet shortcut. XY instead will create "New Internet Shortcut.url" and invoke rename mode.
Up to now it's implemented only for the list. I'll add tree, catalog, and tabs later. I'll also add creation of internet shortcuts by simply pasting URLs (copied from plain text) -- Explorer can't do that! :wink:
Posted: 10 Jun 2006 09:10
by pissant
admin wrote:Only one thing I wasn't able to do: somehow Explorer senses the document title of the web page and uses it as file name for the internet shortcut. XY instead will create "New Internet Shortcut.url" and invoke rename mode.
I'm guessing it has to do with SHDOCVW.DLL and ShellExecute API. But it's probably best to ignore me on this. :lol:
Posted: 10 Jun 2006 09:37
I won't ignore you if you send me working code :lol:
