Find In list
Posted: 03 Dec 2010 10:36
I wish that XYplorer find an item by entering it line number.
And it would be nice that we can find an item by quick search.
Forum for XYplorer Users and Developers
https://www.xyplorer.com/xyfc/
Hi.Thanks.I mean by pressing it line number.For example by pressing 1 2 3 it should show me item 123.jjk wrote:You said "by entering it line number" : see Go > Go to Line...
What do you mean by "quick search" ?
Yes, I see. For Quick search, there is such feature in Total Commander. It is a killer feature.ali_vb6 wrote:Quick search too.Some text like "x*p.exe" should show me "xyplorer.exe".Some where like a textbox under the active pane.
What happens if a file name begins by a digit ?ali_vb6 wrote:I mean by pressing it line number.For example by pressing 1 2 3 it should show me item 123. I want type ahead and not in a dialog.
In this case it should return line number not file name.jjk wrote:What happens if a file name begins by a digit ?
