Tag-comment based filtering of content(like visual filter)
Posted: 24 Jan 2009 23:38
by kartal
This would basically show only certain tags or content of the comments selected by user. It could be part of the search as well.
Re: Tag-comment based filtering of content(like visual filter)
Posted: 25 Jan 2009 00:19
by j_c_hallgren
Some of this may be related to question/answer that is last two posts on page 5 ot File Tags thread (http://www.xyplorer.com/xyfc/viewtopic. ... a&start=60)
Posted: 25 Jan 2009 08:41
Yes, this will come with VL...
Tip: You can use the Selection Filter (Ctrl+M) on columns like this: "comment:honey", or "tag:red;blue", or "tag:gr*" (match Green and Grey)...
Posted: 25 Jan 2009 10:46
by jjk
Super ! Just a little issue : if I filter on "comment:*" all the files/folders are selected, even those without comment. I expected only those having a comment.
Posted: 25 Jan 2009 10:51
by j_c_hallgren
jjk wrote:Just a little issue : if I filter on "comment:*" all the files/folders are selected, even those without comment. I expected only those having a comment.
But doesn't "*" imply a wildcard that anything satisfies? Thus even those with no comment? I agree having a way to isolate only those is needed, but above would be valid reason why it works as is now.
Posted: 25 Jan 2009 10:57
by jjk
Also, with "tag:*", all is selected.
In fact it would be good to be able to select files/folders with any tag/comment (perhaps "tag|comment:?"), and to select files/folders without any tag/comment (perhaps "tag|comment:!?")
Posted: 25 Jan 2009 14:52
Try this pattern: *?* :)
