Configuration Main screen "Apply" button overlaps OK button
Posted: 12 Nov 2025 20:44
by klownboy
Maybe someone has reported this (subject) already on x64 version, beta 28.00.0577. It's fine on x32 beta 27.20.0300.
Re: Configuration Main screen "Apply" button overlaps OK button
Posted: 12 Nov 2025 20:54
Not here, same specs. :?
Posted: 12 Nov 2025 21:45
by WirlyWirly
I've also had this issue for a while, with the various display bugs I've seen lately, I figured it was a tB issue we were waiting on.
Also, on the subject of the configuration window, when I drag it around by the title bar it does so very slowly
I too am running the latest beta, but like I said it has been this way for a few weeks I think.
Posted: 12 Nov 2025 22:19
Hm. I'm seeing none of this here.
Posted: 12 Nov 2025 23:35
by phred
28.00.0577 on Win10.
I'm seeing it also, but only if I look very closely.
Posted: 13 Nov 2025 00:11
by klownboy
I updated my Windows build. Maybe that makes a difference. Who knows. In looking closer, it almost looks there may be a pixel between the 2 buttons but there is definitely no highlighted left edge and no rounded corners on the left side of the OK button (i.e., the edge/rounded corners of the Apply button cut into the left edge/corners of the OK button).
Posted: 13 Nov 2025 01:00
by WirlyWirly
Quick update; The problem is resolved when I run a ::fresh instance.
Posted: 13 Nov 2025 01:13
by klownboy
Yes, mine looks fine in the fresh instance as well.
Posted: 13 Nov 2025 04:24
by phred
klownboy wrote: ↑13 Nov 2025 01:13 Yes, mine looks fine in the fresh instance as well.
Confirmed. No issue with ::fresh
Posted: 13 Nov 2025 09:23
Well, send me your XYplorer.ini, i.e. your settings that cause the problem.
Posted: 13 Nov 2025 09:24
Posted: 13 Nov 2025 13:21
Fixed in next x64 beta.
Posted: 13 Nov 2025 14:08
by klownboy
Thanks Don, confirmed fixed for me in beta v28.00.0588.
Posted: 13 Nov 2025 14:53
by phred
The fix is confirmed. Thanks.
