FastCopy
Posted: 06 Nov 2025 20:31
by Vesparider
Hello everyone,
I am looking for a decent script to set up FastCopy as a custom copy, but unfortunately without success.
Perhaps someone has a tip.
Many thanks.
Kind regards,
Terry
Re: FastCopy
Posted: 06 Nov 2025 23:49
by JohnM
Hi there.
Go to Configuration->File Operations->File Operations and find "External Copy Handlers". Click the "Configure" button and enter configuration info for FastCopy. Once done FastCopy will appear in the drop down box in "Select Copy Handler". Then you can choose it.
Here is my config you can use as a starting point:
External Copy Handlers.PNG (69.06 KiB) Viewed 2157 times
I hope this helps
Cheers
John
