No help entry for Rapid Access Folders
Posted: 06 May 2024 15:21
by Horst
As the subject says.
I can't find any help entry for it ?
Re: No help entry for Rapid Access Folders
Posted: 06 May 2024 21:45
by Borut
Just being currently developed. Help will surely come... Patience.
In my eyes the RAF is a new game changer. Therefore I have the following question: Shouldn't it also follow the tweak AutoOptimizeTreeRadical=1 ? I could be wrong, but it seems to me that in this respect the RAF area is currently behaving differently then the rest of the tree. But maybe I am the only one using this option...
Posted: 07 May 2024 08:42
You mean the whole RAF section does not auto-collapse when it should?
Posted: 07 May 2024 09:05
by Borut
Exactly. Neither when I change between the 1st subdirectories of "Rapid Access" (they all remain expanded), nor when I change to some other area of the "normal" tree (everything what has been expanded under "Rapid Access" until then remains expanded. (In the opposite direction, when I "leave" some branch of the "normal" tree and click into the RAF area, the normal tree does not stay expanded - this is as expected, always was so and is OK.)
I have meanwhile experienced the following strange and very seldom cosmetic issue, which occurs (repeatably) only under the following conditions (not tested with fresh!): Start XY; open a tabset (no RAF involved, just "normal" locations, but the following might be of importance: my first opened tab is in the network, on a logical drive); while in that tab, click on "Rapid Access": In List, the two fields are not automatically expanded as expected! It is only after Ctrl-+ that they appear as expected. Probably a very special case. Thanks!
Posted: 07 May 2024 09:52
1) Fixed.
2) Cannot reproduce. Some additional factor must be at play.
Posted: 07 May 2024 09:55
by MBaas
Will there also be scripting command to read/write the RAF list? (or is already doable?)
Posted: 07 May 2024 10:45
Sure, later.
Posted: 08 May 2024 08:14
by jupe
Hey Don, today I just upgraded to .0135 for my first test of RAF, seems extremely useful, nice job. :tup: :cup: :beer:
I have noticed though that some of my RAF icons seem to be smaller, I think it is a dpi thing, below is a screenshot that shows the same icons in the catalog for a size reference, as you can see, in the RAF tree xy internal icons are shown smaller.
Another thing that happened during today was about 10 silent closes, usually happened when I just switch back to the XY window from another app/instance, can't see any pattern yet. :(
Oh yeah, and why haven't you fully authored the help file and given full scripting support simultaneously with the first beta release of this new major feature. /s
:shock:
Posted: 08 May 2024 11:56
by klownboy
jupe wrote: ↑08 May 2024 08:14 Another thing that happened during today was about 10 silent closes, usually happened when I just switch back to the XY window from another app/instance, can't see any pattern yet.
I noticed that as well yesterday. I don't have a glue as to why, only that it happened about 3 or 4 times.
Posted: 08 May 2024 12:10
1) Icons, yep, fix on the way.
2) Silent close. Hmm. Not here so far. :eh:
3) :lol:
