simply script ascii to hex
swan_x
Post by swan_x »
hi there, i need a simply script to rename a selected file to hex value and viceversa
any tips?
swan_x
Re: simply script ascii to hex
Post by swan_x »
my request it's really hard?
i see 31 views to my thread but 0 replies
and it's really strange for me: from web resource there are many sites that allow this, such as:
https://online-toolz.com/tools/text-hex-convertor.php
https://onlinehextools.com/convert-text-to-hex
https://www.calculators.tech/text-to-hex
and also on np++ have a good plug-in Converter ascii to hex and viceversa, but i would like a script to use directly in xy for the renaming of any file, without going through np++ or browser
but perhaps it is more the will that does not want to answer than the problem itself.
and even if don't understand the reason, ok i accept this and i will look for other solutions
Look up asc() and hex().
Norn
Post by Norn »
"Text to Hex (Rename base)"
 $items = get("selecteditemspathnames");
 foreach($item, $items, "<crlf>", e) {
    $itemName = regexreplace($item, "(.*\\)(.*)(....)", "$2");
    $hexdump = hexdump($itemName, 1, r);
    $hexdump = replace($hexdump, " ", "");
    renameitem($hexdump, $item);
"Hex to Text (Rename base)"
    $hexdump = hexdump($itemName, 1, "ri");
"Text to Hex (Rename all)"
    $itemName = regexreplace($item, "(.*\\)(.*)(....)", "$2$3");
    renameitem($hexdump, $item, 3);
"Hex to Text (Rename all)"
Rename selected items at once:
 $newNames = "";
    $itemEXT = regexreplace($item, "(.*\\)(.*)(....)", "$3");
    $newNames .= "$hexdump$itemEXT<crlf>";
 rename l, $newNames, , $items;
 $newNames = "";
 $newNames = "";
    $newNames .= "$hexdump<crlf>";
 $newNames = "";
swan_x
Post by swan_x »
@Norn a big thank you for your code
just a note: for my intent, i need only the second part, 'Rename selected items at once'
 $newNames = "";
 $newNames = "";
but with this code, all space is converted in hex on 00
example: if i have to rename New Text File.txt with your code i have 4E0065007700200054006500780074002000460069006C006500.txt
with this link (only to example) https://online-toolz.com/tools/text-hex-convertor.php i have:
New Text File.txt -----> 4e657720546578742046696c65
without 00 and all letter lowercase
Post by RalphM »
swan_x wrote: 25 Jun 2022 09:31 my request it's really hard?
Really, this was after one day - maybe you should increase your patience and decrease the neediness! :whistle:
Ralph :)
Decreasing laziness might also be a way.
Norn
Post by Norn »
"Without 00 (English only):"
 $newNames = "";
	$hexdump = replace($hexdump, " 00 ", "");
 $newNames = "";
	    $case = "1";
        $pos = "";
		$newBase = "";
	    while ($pos++ < strlen($itemName)) {
          $word = gettoken($itemName, $pos, "");
          $next = gettoken($itemName, $pos + 1, "");
		  if $case == "2" {$case = "1"}
		  if $case == "0" {$case = "2"}
          if($case == "1") {$newBase .= "$word$next" . " 00 "; $case = "0";}
    $hexdump = hexdump($newBase, 1, "ri");
 $newNames = "";
 $newNames = "";
	    $case = "1";
		$pos = "";
		$newBase = "";
          if($case == "1") {$newBase .= "$word$next" . "00"; $case = "0";}
"Support non-English:"
 $newNames = "";
 $newNames = "";
 $newNames = "";
 $newNames = "";
swan_x
Post by swan_x »
simply wonderful
Thank you so much Norn
