Directory Opus Theme?
Posted: 20 Feb 2021 00:52
by KBConcepts
Does anyone know how to make XYplorer act and appear like Directory Opus?
Re: Directory Opus Theme?
Posted: 20 Feb 2021 01:52
by RalphM
Troll?
The easiest way is to change DO's title bar to XYPlorer - done!
If you are here because you like XY better - for whatever reason - then you might have to learn to live with the differences.
However, if you like DO so much, then you should probably just stick with it.
Posted: 07 Mar 2021 09:50
RalphM wrote: 20 Feb 2021 01:52 The easiest way is to change DO's title bar to XYPlorer - done!
LOL :tup:
