Page 1 of 3
Little problem with preview
Posted: 06 Jan 2008 12:05
by gtaillandier
Hello
I have version 5.55.0001 and when I preview several .flv video they're not well displayed. It's just like a rotation has been applied.
Can someone help me ?
Sincerely.
Re: Little problem with preview
Posted: 07 Jan 2008 10:45
I never had this phenomenon... no idea what's causing it.
Posted: 07 Jan 2008 18:22
by gtaillandier
Hello
Can you tell me if it's possible to send you the video ?
If it can help.
Posted: 07 Jan 2008 18:24
gtaillandier wrote:Hello
If it can help.
Yes, send it by email.
Posted: 07 Jan 2008 18:48
by gtaillandier
The video is 10990 KB.
Can you send me the e-mail adress by private message ?
Sincerely.
Posted: 07 Jan 2008 18:57
gtaillandier wrote:The video is 10990 KB.
Sincerely.
Upload it somewhere...
Posted: 07 Jan 2008 19:08
by j_c_hallgren
admin wrote:Upload it somewhere...
gtaillandier: This is the best solution as it allows other forum folks to see how it reacts on their systems also...and there are numerous places to do so easily and freely.
Posted: 07 Jan 2008 21:00
by gtaillandier
Here's the link where the video has been uploaded :
http://dl.free.fr/iMb7RInJO/2019582801[1].flv
Posted: 07 Jan 2008 21:26
by serendipity
Plays fine for me with version 5.55.0001. It could be the codecs, but not sure.
BTW, you can try to add flv extension to XY file associations (Menu "Tools>List management>File associations") and see if that helps. Eg:"flv>C:\Program Files\Windows Media Player\wmplayer.exe" if you use windows media player.
Posted: 07 Jan 2008 21:35
by gtaillandier
In "Tools>List Management", I don"t have "File associations".
The problem is not with all videos, but with a few one only.
Why ?
Posted: 07 Jan 2008 21:52
by Jeff Bellune
I can play the video just fine in Sorenson's FLV player, but it hangs XY 6.80.0006. The UI becomes non-responsive and the preview panel only shows "Loading"
-Jeff
EDIT: It's system problem here because it also hangs WMP.
Posted: 07 Jan 2008 21:59
by serendipity
gtaillandier wrote:In "Tools>List Management", I don"t have "File associations".
I dont understand,
1) you dont have the submenu "File association" in list management OR
2) you dont have anything inside file associations window?
If its 1 then there is something wrong because its supposed to be there. Reinstall XY then. If its 2 then add the flv association to the window.
Why ?
Certainly its not the XYplorer file manager because your uploaded video plays fine for me. Remember that it depends on how the FLVs were made or encoded from. probably your system can play FLVs that were encoded from one format but not another.
Read-up:
http://en.wikipedia.org/wiki/Flv
Plays fine here.
Posted: 07 Jan 2008 22:20
by j_c_hallgren
Ok, so I'm not using the old vers 5.55 but am using 6.80.06, and here that FLV only plays audio in XY! It plays fine via VLC Media Player and Riva FLV Player and Applian FLV player, however...
Posted: 07 Jan 2008 22:24
j_c_hallgren wrote:Ok, so I'm not using the old vers 5.55 but am using 6.80.06, and here that FLV only plays audio in XY! It plays fine via VLC Media Player and Riva FLV Player and another FLV player (that I don't recall where I got it), however...
I use K-Lite Mega Codec Pack 1.59. No problems.
