Create folder with increments Syntax
Posted: 27 Feb 2017 03:03
by yusef88
1- why increments Syntax can be used in renaming items but cannot used in creating new folder?
2- in win explorer, I don't have to select the 2 items (as appears in the picture) to delete a saved web page, Can XY do the same thing?
thanks
Re: Create folder with increments Syntax
Posted: 27 Feb 2017 05:46
by highend
2.
v16.10.0310 - 2016-01-16 14:53
* File Operations using the shell (not Custom Copy): From now on XYplorer
will avoid the odd "Connected Files" smartness that has been introduced with
Win 2000 (
https://msdn.microsoft.com/en-us/librar ... #connected ),
e.g. "XY.htm" file + "XY-files" folder. Deleting or moving or copying one
of such a couple would also delete or move or copy the other. Madness.
This will not happen anymore in XYplorer from now on.
