Search Results Tab Locked isn't
Posted: 30 Sep 2013 19:31
by aurumdigitus
Using v13.00 and discovered this today. Despite having Show search results in: "Search results" tab (locked) active, found out the hard way that accidentally clicking the X on the tab closed Search Results. :cry:
Re: Search Results Tab Locked isn't
Posted: 01 Oct 2013 03:36
by Enternal
That's odd. Mine prompted me when I hit the x on the tab. Can you try it with a fresh install and see if it still happen?
Posted: 01 Oct 2013 03:43
by j_c_hallgren
Enternal wrote:Can you try it with a fresh install
And remember that you can use the "fresh" switch instead of making a new copy if you want, but also use last beta as well.
Posted: 01 Oct 2013 10:09
aurumdigitus wrote:Using v13.00 and discovered this today. Despite having Show search results in: "Search results" tab (locked) active, found out the hard way that accidentally clicking the X on the tab closed Search Results. :cry:
1. Locked Tabs are recognizable by an underlined caption.
2. You are prompted before a locked tab is closed (unless you turned this off (unless you unticked Configuration | Tabs | Prompt on closing a locked tab)
3. You can restore an accidentally closed tab by View / Tab / Restore Closed Tab.
So, "found out the hard way" might be slightly overdramatized... ;)
Posted: 01 Oct 2013 14:49
by aurumdigitus
Thanks for the help and guidance. Will trouble shoot later today.
Over the years have gone through numerous upgrades. Every once in a while something has gotten changed during that process. Will try to ferret out what happened. If this was going on before 13.00 missed it.
