Here's the new BETA (32-bit)
Get a glimpse of the next XYplorer...
Locked
Re: Here's the new BETA
Change Log for the latest XYplorer BETA version:
v19.40.0182 - 2018-12-18 18:15
    + Dark Mode: XYcopy (background file operations) supports dark mode now.
    * XYcopy: Updated to 2.10.0133.
    ! Full Row Select: Text color wrong on an unfocused selected labeled
      caption. Fixed.
    ! Dark Mode: Fixed some glitches.
To download the latest BETA version choose a download package: (1) Installer Package, (2) No-Install Package.
:!: Note that BETA versions are work in progress and might contain fresh bugs. You have been warned.
It's a good idea to backup your complete XYplorer settings (menu File | Settings Special | Backup Application Data Folder...)
before running a new BETA version. This will also help in fixing any fresh bugs.
v19.40.0184 - 2018-12-19 12:15
    * Configuration | Colors and Styles | Lines, Planes, Dark Mode: Renamed the
      page to "Highlights & Dark Mode".
    - Removed this change from v19.40.0168 - 2018-12-15 14:35:
      * List: Column headers are now drawn slightly darker than white if both list
        back and headers would be white according to the Windows Theme. This is
        the case in Win10 currently.
    ! Full Row Select: Still text color wrong on certain conditions. Fixed.
    ! Breadcrumb Bars: Clicking on a folder on the breadcrumb while app was in
      the background didn't restore focus on the XYplorer window. Fixed.
    ! Special Properties: Property "Date Taken" did not all times correctly when
      the system format was set to AM/PM. Fixed.
v19.40.0187 - 2018-12-19 18:16
    + Hover Box: Now images tell you the percentage of the preview compared to
      the original. It's one-dimensional: 120 x 120 shown as 60 x 60 is "50%".
v19.40.0188 - 2018-12-20 15:25
v19.40.0189 - 2018-12-20 22:07
v19.40.0190 - 2018-12-21 12:53
    * Updated the help file.
Summary of the latest XYplorer Official Release.
Download: https://www.xyplorer.com/download.php
v19.50.0000 - 2018-12-21 18:00 - The Werewolf Edition
    = NEW OFFICIAL RELEASE. Main developments since last release:
  +++ Dark Mode. Now XYplorer offers a portable, smart, instant dark mode. Just
      one click and the app turns dark in the blink of an eye. You can control
      the levels of darkness and text contrast to adjust the dark mode to your
      needs and likings. Works in each Windows version from XP onwards.
  +++ Compilation Soundtrack. Compiled to the music of Angaleena Presley.
v19.50.0003 - 2018-12-22 22:22
v19.50.0004 - 2018-12-23 17:25
    * Find Files: Replaced the ugly Windows "*.fnd" icon by my nice toolbar
      graphics. Everywhere.
v19.50.0006 - 2018-12-29 11:51
    + Added tweak to show informative file info tips for EXE files:
        FileInfoTipExe=1
      This had been removed recently and silently because under Win10 file info
      tips for EXE files got extremely slow (probably due to anti-virus).
    ! GUI could break temporarily when app was minimized on a Windows theme
      change. Fixed.
v19.50.0100 - 2018-12-29 18:00
    = MAINTENANCE RELEASE.
  +++ Minor bug fixes and enhancements.
v19.50.0101 - 2019-01-02 19:21
    + Custom Toolbar Buttons: Now you can define the color for a circle drawn as
      background to your icon. This can be useful in Dark Mode where some dark
      icons otherwise tend to disappear in the darkness.
      You simply append the RRGGBB color spec to the icon spec, separated by
      "*#" (yes, this is a bit weird but there is a lot of parsing going on and we
      don't want any ambiguities), for example (in the Edit User Button dialog):
        Icon: c4.ico*#F6F6F6
      This will draw a circle of color #F6F6F6 behind your "Dark Cloud" icon
      "c4.ico". The Dark Cloud will be visible in Dark Mode.
      Note that you can abuse this feature to use colored circles as icons.
      Simply drop the file name:
        Icon: *#FEB914
    + Catalog: The same colored background circle trick also works in the
      Catalog when you use custom icons for an item. For example:
        Caption: umlaut-phobia|c3.ico*#F6F6F6
    ! Dark Mode: The following toolbar graphics did not work well in Dark Mode:
      - Customize Keyboard [cks]
      - Manual Sorting [mansort]
      Now they do.
v19.50.0102 - 2019-01-03 18:42
    + Configuration | Information | File Info Tips: Added option "For
      executables as well". Tick it to show informative file info tips for EXE
      files.
      It's optional because under Win10 file info tips for EXE files got
      This raises the tweak FileInfoTipExe to the UI.
    + Custom Toolbar Button Backgrounds: Now you can define a rectangular shape
      by appending "r" separated by a comma, eg:
        Icon: c4.ico*#F6F6F6,r
    + Custom Toolbar Button Backgrounds: Now they also work with toolbar
      graphics, eg:
        Icon: :ghost*#F6F6F6,r
    ! Hover Box: Long filename could be cropped too late when icon was shown in
      the status section. Fixed.
v19.50.0104 - 2019-01-04 16:36
    + Configuration | Colors and Styles | Styles | Show Age maximum hours: Now
      you can also specify factors with date units other than "hour", e.g.:
        Value   Meaning
           1    1 hour
          1h    1 hour
          2d    2 days
          3w    3 weeks
          4m    4 months
          5q    5 quarters of a year
          6y    6 years
    % Toolbar in Dark Mode: Improved the look of the "Toggle Instant Color
      Filter" button.
      If you want to use it in custom buttons etc, the key is ":icfdark".
    * Breadcrumb Bars in Dark Mode: Now the inactive pane's breadcrumbs are
      drawn a bit darker. Makes the active pane stand out better.
    ! Breadcrumb Bars in Dark Mode: Border color was not dark yet when
      "Configuration | Colors and Styles | Highlights & Dark Mode | Borders" was
      set to "Windows Theme Style". Fixed.
    ! Info Panel: When switching to Dark Mode tabs where drawn non-dark when
      "Configuration | Tabs and Panes | Tabs | Visual style" was set to "XYplorer
      Classic Style". Fixed.
      The switch is still not perfect under these rare conditions. There's a
      minor glitch left that will be fixed later.
    ! SC extracttext: Did not work anymore since 20181130. Fixed.
v19.50.0105 - 2019-01-05 16:52
      you can also use date units smaller than "hour":
        Value   Meaning
          12n   12 minutes
        1000s   1000 seconds
    ! Custom Copy: Report wrongly showed "| None:" instead of "| byte-to-byte"
      for verified copies. Fixed.
    * XYcopy: Updated to 2.10.0134.
    ! MLS: Language switch did not work alright in Russian. Tried a fix.
Locked
