Skin: Mosaic
Skin: Mosaic
Another skin for use with the new XYplorer PatchImages skinning system. For usage, see documentation for the Onyx skin here--
viewtopic.php?f=7&t=20333
mosaic.bright.zip -- full color & brightness version
mosaic.faded.zip -- color faded to 50%
mosaic.gray.zip -- completely grayscale (maybe not quite as intuitive for some buttons)
mosaic.xtra.zip -- extra and alternate images for ctb's and menus (alternates need renaming; best not to put extras in "IconsPatch" folder)
[edit 2019.04.10] zip files updated--icon file names standardized and extraneous hidden files removed.
[edit 2019.04.10] zip files updated--grayscale versions bg's fixed, "delete" icon & other small fixes, custom icons moved to own zip
[edit 2019.04.11] new preview & faded version added; zip files updated with fixes & new hidden items & folder view images
[edit 2019.04.13] zip files update w/ misc fixes & new rfo image with prev rfo image moved to extras
- mosaic.bright.zip
- (419.88 KiB) Downloaded 245 times
- mosaic.faded.zip
- (413.9 KiB) Downloaded 193 times
- mosaic.gray.zip
- (404.84 KiB) Downloaded 209 times
- mosaic.xtra.zip
- (86.39 KiB) Downloaded 202 times
Re: Skin: Mosaic
These are beautiful!
some of the gray version images have a white background. I think they will look just fine without that.
Also you can significantly decrease the package size by removing the Thumbs.db files.
On a pragmatic note, I think removing the .mosaic[-gray] suffixes from the image names will be better for application. This way, I can just copy them overwriting existing active skin images. On the other hand, with the suffixes, I end up with duplicate files, requiring manual cleanup (for now).
Re: Skin: Mosaic
Thanks for feedback. Glad you like. File names standardized and db files removed (silly ghost filter.. ) from zips per suggestions. Will have to investigate the white bg's in gray icons. I confess the grays are a bit of a side project that didn't get nearly as much attention but white bg's shouldn't be there. Let me know if you see any other issues.
Re: Skin: Mosaic
Hi sfwood, very nice skinsets. Thank you.
I noticed when I ran Sammay's "_unlock.sys" on the mosaic or mosaic-gray skinsets that we get an invalid key on two of the keys "dpbackupto" and "preview-tab-info" on code line
patchimage $key, '', $size;
. It only occurs on those two key image files. There is a dpcopyto and dpmoveto but no dpbackupto. Sammay's key files obviously use a specific naming configuration and the script uses that but the script runs fine on the Mosaic and Mosaic-gray skinsets other than those two key files. I couldn't find them in the Customized Toolbar listing so they must be invalid. Thanks again. Windows 11, 23H2 Build 22631.3447 at 100% 2560x1440
Re: Skin: Mosaic
Yeah, to be expected. Those are extra icons for custom buttons / menu commands. Safely ignored by XY at startup but if Sammay's "_unlock.sys" script iterates through all files in the folder and tries to force them in XY's not going to like that. I will handle however Sammay tells me to--he's the boss.
Re: Skin: Mosaic
Thanks. Sammay's _unlock.xys script is simply looping through a designated folder and unlocking the patch files (i.e., using SC patchimage to remove the patch image) so when it comes across one that doesn't exist, there's a hiccup. Burp! Maybe there is someway in the script to ignore an image file that has no corresponding XY's built-ins to avoid the error or just not place any image files in the skinset folders which do not have a corresponding XY built-in.
Re: Skin: Mosaic
There's no way to detect invalid keys at the moment, and I'm not very enthuasiastic about manually managing a potentially dynamic list of acceptable keys in _unlock.xys or any future skinset utility. I'm afraid those hiccups are here to stay unless Don does something about it.
I'd argue the <PatchImagesPath> is not really a place for storing arbitrary icons, so supplying extra icons as a sub-skinset package (as I've done with Onyx.extra) is probably a good way to go, until some better community standard is achieved.
I myself keep a <xyicons>\ctb directory whence all my ctb icons are sourced. My skinning workflow would be to place images from those extra skinsets and if needed rename them to ctb-specific names, and that completes ctb skinning. This cannot be scripted in a one-size-fits-all process though.
Re: Skin: Mosaic
I had tested a few things myself and I couldn't find any way to test for a valid XY built-in key. I mentioned that only because I figured you may at some point be devising a way through a menu or whatever to change skinsets or revert back to XY's original. Your _unlock script does its job nicely as long as we're using valid keys.
Re: Skin: Mosaic
First day fixes--zip files have been updated twice with following changes:
"delete" icon corrected & other small fixes
custom icons moved to separate zip file
Re: Skin: Mosaic
you may want to add skins for the keys :fvsp and :fvsd too.
[ viewtopic.php?f=7&t=19929 ]
Otherwise the stock fvs button sticks out like a sore thumb when browsing a folder with fvs active.
fvsd = Folder View Settings [disabled]
fvsp = Folder View Settings [active]
Re: Skin: Mosaic
yup--these have been added to the image zips linked in original post. the 50% color version is there now too. thanks.
- fvs.png (3.3 KiB) Viewed 5096 times
- fvsp.png (3.24 KiB) Viewed 5096 times
- fvsd.png (3.03 KiB) Viewed 5096 times
Re: Skin: Mosaic
nice. more choices too, great!
Re: Skin: Mosaic
These mosaics are great thanks for the updates and new skinsets.
