Custom column for "number of lines" in a CSV or TXT file?
pdanese
Post by pdanese »
I am running a trial version of XYplorer (19.70.0100).
Is there a way to create a custom column that shows the number of rows/lines in a CSV or TXT file?
For example, you can determine the number of lines in a csv file from the command prompt using:
 findstr /R /N "^" myfile.csv | find /C ":"
, but I am not sure how to incorporate that into XYplorer (or if it's even possible).
The information doesn't necessarily have to be presented in a custom column. If there is a more appropriate way to display this type of metadata in XYplorer that would be great, too.
Thank you.
Re: Custom column for "number of lines" in a CSV or TXT file?
type snippet; into the address bar, execute that command with the {ENTER} key
Paste this into the edit box of that new window that appears:
Snip: CustomColumn 1
  XYplorer 19.70.0119, 10.03.2019 05:43:26
Action
  ConfigureColumn
Caption
  Lines
Type
  3
Definition
  return trim(runret("""cmd"" /c findstr /R /N ""^"" ""<cc_item>"" | find /C "":"""), <crlf>);
Format
  0
Trigger
  0
Item Type
  0
Item Filter
  csv;txt
Hit the OK button
Add that new custom column...
pdanese
Post by pdanese »
Thank you again. Wonderful piece of software (and help).
