Script request: Apply tags to selected folders and its subfolders
Re: Script request: Apply tags to selected folders and its subfolders
The script part you've posted doesn't contain a closing curling brace
so
if ($P_TagOptions == "D") {
was executed
regardless if the if clause was true or not. So check that $P_TagOptions
variable
The code I've posted works with that variable set to "D"...
karimmaster101
Post by karimmaster101 »
So weird! I set Tagoptions to D too. Here it is full code I am using. I got no syntax errors at all
Should I change anything?
"Apply tag"
    $notes = ($P_TagOptions == "D") ? "Directories only": "Directories AND files";
    if (!$tag) { status "No tag entered, aborted", , "alert"; end true; }
    $selItems = get("SelectedItemsPathNames");
    // Directories only
        $selFolders = GetFoldersOnly($selItems, <crlf>, <crlf>);
              // Selected folders
        if ($selFolders) {
            $items = formatlist(quicksearch("lbl:** /d", $selFolders), "sed", <crlf>);
        // No selected folders, use folders in <curpath>
        } else {
            $items = formatlist(quicksearch("lbl:** /d", listfolder(<curpath>, , 2, <crlf>)), "sed", <crlf>);
    if ($items) {
        tagitems("label", "", $items);
        status "All items tagged...", , "ready";
function GetFoldersOnly($items, $inSep="|", $outSep="|") {
    $list = "";
    foreach($item, $items, $inSep, "e") {
        if (exists($item) == 2) { $list = $list . $item . $outSep; }
    return formatlist($list, "sed", $outSep);
Where? Not in that script...
karimmaster101
doesn't this
what you mean when you said set to D.
I'm totally newbie here, so I think that's it.
What's wrong in my final code? What should I change?
I am so sorry for my lack of knowledge here, but I am trying my best
No, that is checking if it was set to "D".
Look at the first script:
"_Initialize"
perm $P_TagOptions;
if (!$P_TagOptions) { $P_TagOptions = "D"; }
That was the original setting
So at least make sure that
is true by adding a new line after it with
echo "inside if clause";
and if you see that message box on the next
execution show exactly what is not working
by listing in which folder you are, what is
selected and which subfolders have a label
in that structure...
karimmaster101
At first I want to know that I am really appreciate your help very much. Many thanks!
Here it is the final code I am using:
"_Initialize"
    perm $P_TagOptions;
"Option: $P_TagOptions"
    if ($P_TagOptions == "D") { $P_TagOptions = "D+F"; }
    elseif ($P_TagOptions == "D+F") { $P_TagOptions = "D"; }
    else { $P_TagOptions = "D"; }
    load "*", "Apply tag", "s";
"Apply tag"
    // Directories only
              // Selected folders
        if ($selFolders) {
        } else {
    if ($items) {
    $list = "";
Here are the issues:
1- Every time I run the script it shows a menu and I should click on "Apply tag" to make it run ..... I don't want this menu to appear, just excute the script without choosing any options
I figured that out :lol: I just commented out all Options part. I hope that I didn't make any mistakes here
// "Option: $P_TagOptions"
    // if ($P_TagOptions == "D") { $P_TagOptions = "D+F"; }
    // elseif ($P_TagOptions == "D+F") { $P_TagOptions = "D"; }
    // else { $P_TagOptions = "D"; }
    // load "*", "Apply tag", "s";
2- In "Current path" scenario, it takes a while to execute the script, during this time whenever I browse any tab or folder it shows "The view is empty"
.... I want a workaround to solve this, like loading popup so I know that something working on background or so.
Again, many thanks
Apart from the script command status there aren't any more non-intrusive "I do something now..."
ways, so:
    $selFolders = GetFoldersOnly(get("SelectedItemsPathNames"), <crlf>, <crlf>);
    if ($selFolders) { // Selected folders
    } else { // No selected folders, use folders in <curpath>
        msg "Unlabelling folders will now start...";
    if ($items) {
        msg "Unlabelling finished!";
    $list = "";
Remove the second msg command if you don't like it...
karimmaster101
This not what I meant.
I mean that I want to make Xyplorer unresponsive (Can't open folders, or switch to another tabs) while executing the script.
Not possible (at least not without an external tool, that wouldn't allow mouse clicks while the script is running. Though it's easy to write such a tool)...
karimmaster101
highend wrote:Not possible (at least not without an external tool, that wouldn't allow mouse clicks while the script is running. Though it's easy to write such a tool)...
I can live with that, no problem!
Another irrelevant question: I want to change the "Sort folder always ascending" setting via a script, is that possible?
I found that I could change "SortFoldersApart" setting and there is no mention about "Sort folder always ascending"
Many, many, and many thanks for your amazing help!
Extract the attached .zip file and put the xyLockWhileScriptInProgress.exe anywhere you like.
Adapt the $path (and $exe if necessary) variable in the script...
The tool locks all left mouse button clicks while the script is running and displays a progress bar...
    $path = "D:\Users\Highend\Development\AutoHotkey\#NOT UNDER ACTIVE DEVELOPMENT\xyLockWhileScriptInProgress";
    $exe  = "xyLockWhileScriptInProgress.exe";
    $bat = "%TEMP%\~killLock.bat";
    $batContent = <<<>>>
@FOR /F "tokens=1,2,9 delims=," %%P IN ('TASKLIST /NH /V /FO CSV ^| FINDSTR /IL "$exe"') DO (TASKKILL /F /PID %%Q)
    writefile($bat, $batContent);
    run """$path\$exe""";
    if ($items) {
        status "All items unlabelled...", , "ready";
    run """$bat""", , 2, 0;
    delete 0, 0, $bat;
    $list = "";
xyLockWhileScriptInProgress.zip
(394.02 KiB) Downloaded 103 times
It is but it won't get activated until XY is restarted...
karimmaster101
WOW, That's great :appl: :appl:
I was hoping that it won't need restarting.
