Assign Insert key to (de)select files
noembryo
Re: Assign Insert key to (de)select files
Post by noembryo »
admin wrote: 15 Jun 2022 11:54 Again, how do you skip an item (one that you don't want to select)?
Horst wrote: 13 Jun 2022 19:52 Using the cursor down key.
The problem with XY is that moving the cursor to the next line removes all selections.
But it doesn't have to be identical to TC.
Perhaps a ctrl+Ins could be used..
Check my free programs here..
Not convincing. :|
raraz
Post by raraz »
Horst wrote: 13 Jun 2022 19:41 ...
It should select the current item and position the cursor to the next item.
This way one can go forward and select several items.
Skipping is with cursor-down.
But the problem is that moving the cursor to the next line removes all selections.
Exactly, that's the problem. How is it handled in TC?
Post by Horst »
admin wrote: 16 Jun 2022 18:38 Exactly, that's the problem. How is it handled in TC?
It handled as I have descibed it above.
As long as one uses the cursor Up/Down keys the selection is not changed
and any item can be toggled/added by the INS key or of course with a Ctrl-Click with the mouse.
Very convenient and I think easy to implement :)
Windows 11 Home x64 Version 23H2 (OS Build 22631.3447)
Portable XYplorer (actual version, including betas)
Everything 1.5.0.1372a (x64), Everything Toolbar 1.3.3, Listary Pro 6.3.0.73
Is it correct that this mode goes back to Norton Commander?
BTW, Tools | Customize List | Sticky Selection is pretty close, with the SPACE key already doing what INS now does.
Post by Horst »
admin wrote: 16 Jun 2022 19:34 Is it correct that this mode goes back to Norton Commander?
Its from the old Norton but my Total Commander expirience and license goes back to the times of Windows for Workgroups 3.1
The Sticky selestion does nothing useful for me in this case.
it just sets a Live filter and if I hit the space key
it hides some entries or a lot of entries without any logic for me.
You need to set this tweak:
TAFSkipSingleSpaces=1
I will raise it to GUI soon.
Post by Horst »
admin wrote: 17 Jun 2022 18:04 You need to set this tweak:
Ok, better with this tweak
but I miss the forward to the next file in the list when INS is pressed.
So this is still not so convenient as in TC
Give me a cool name (something without "NC" or "TC") for this archaic mode and I'll add it, at least as a tweak.
E.g. "Jurassic Mark" :)
Post by Horst »
TCfreakMode :)
I went for this (next beta):
SelectOldSchool=1
No mention in the change log, it's too weird.
Post by Horst »
Thanks :D
I feel at home
Works perfect now
Evolve
Post by Evolve »
Sorry for off-topic. How do I select two separate intervals with keyboard? Ctrl+Shift+Space doesn't seem to work.
Assuming default settings, should be able to with Shift+Down for first selection, then Ctrl+Down to next group then Ctrl+Space then Ctrl+Shift+Down
