HoverBox improvements
Re: HoverBox improvements
klownboy wrote:I believe this has been asked before, but since you are on a roll with HoverBox improvements (and a very good roll it is), any possibility for gif movement in the HoverBox? :ninja:
Anim Gif is tricky. I might leave this for HoverBox 3.0... but I'll check later...
UPDATE: Nope, that's too much for now. Gonna come with HoverBox 3.0...
admin wrote:Anim Gif is tricky... Gonna come with HoverBox 3.0...
OK Don, no problem. Thanks.
Windows 11, 23H2 Build 22631.3447 at 100% 2560x1440
SkyFrontier
Post by SkyFrontier »
Can text-preview have no other side effects like popping info tips on folders? (.90.0118) Attached under 'show file info tips' it does make sense, but it's a price I would not like to pay for having it enabled eternally as it's a must for me (another long time wish).
Yes. :)
SkyFrontier
yay! :beer:
Post by TheQwerty »
Don, can you check and confirm the behavior when Show info tips only while the shift key is held down is enabled?
What I'm seeing is that shift+hover shows HB and ctrl+shift+hover does nothing.
I expected and would prefer ctrl+shift+hover to show the info tips when that option is enabled.
TheQwerty wrote:What I'm seeing is that shift+hover shows HB and ctrl+shift+hover does nothing.
Yep, next version.
Leito
Post by Leito »
Should it be made clearer that the options shown below are applicable to the Hover Box as well?
I'm seeing a weird placement of my Hover Box when XYplorer is located on my second screen :
This is what I get (and what's expected I think) when XYplorer is located on my main screen :
Leito
Post by Leito »
The Hover Box doesn't seem to be working on new Office files (docx, xlsx...) while it works on Office 97-2003 files (doc, xls...). In action below on a docx file, with the preview pane showing that XYplorer is able to preview the docx file:
I observed the same on xlsx/xls files.
suslo
Post by suslo »
i wish the hover box (text files) could be customized to look like exactly as the text preview which is displayed when the 'mouse down blow up' feature is used
1) mouse down blow up requires a click (hover box does not require a click)
2) but mouse down blow up offers text-preview that is so much more good-looking:
- no huge dark borders
- no unnecessary additional info (size, modified...)
- no '... [continues]' inscription
- just the content of a file (inside thin tidy border)
- substantially greater quantity of lines are displayed which is very important
so the idea is to simultaneously have:
- 0-click feature (as with the hover box)
- and bigger/more informative/more neat and more visually pleasant text preview (as with the mouse down blow up)
I plan something else you might like: Once the HoverBox is up, you can scroll through the text using wheel or arrows.
Leito wrote:The Hover Box doesn't seem to be working on new Office files (docx, xlsx...) while it works on Office 97-2003 files (doc, xls...).
I'm planning full 64-bit shell extension support in the future. Then your issue will be history.
Leito wrote:I'm seeing a weird placement of my Hover Box when XYplorer is located on my second screen...
Do you get the same weird placement with Mouse Down Blow Ups?
Leito
Post by Leito »
Great!
Nope. MDBU is correctly placed.
Weird! According to the code both are handled identically. :eh:
Could you place your mouse to pop one of those misaligned HoverBoxes and then run this through the address bar via ENTER and post the return:
screen;
