HoverBox improvements
Re: HoverBox improvements
Don, your move is in the direction I wanted to suggest. The rest of my suggestion would be:
Adapt the positioning logic of both HBOF (=hover box over folder) and MDSU in such a way that the real list parts of both (i.e. when footer area part of HBOF is not considered) are positioned exactly at the same pixel. In my view this would be very cool.
And after the Phase 2 (Scrolling) and Phase 3 (folder to folder traversal in MDSU) are once completed, it will finally be there: The first file explorer using Wormholes for file space exploration.
Win 10 Pro 64bit
The position of the Hover Box is so that you see the captions of the hovered and of the neighboring items (if possible within the screen). I think I want to keep it like that.
I'll keep that in mind for promotion...Borut wrote:And after the Phase 2 (Scrolling) and Phase 3 (folder to folder traversal in MDSU) are once completed, it will finally be there: The first file explorer using Wormholes for file space exploration.
I'm liking the Polaroid look for Hover Box images. It seems to make the images standout - much more so than the dark frame.
Windows 11, 23H2 Build 22631.3447 at 100% 2560x1440
In a multi-screen environment, could you make it so that the whole HoverBox stays on the screen where the XYplorer window is? Currently the HoverBox steps over the other screen.
Is this image displayed when the mouse pointer is placed in the name of a folder that contains subfolders?
Yes, called "Hover Box".CompSystems wrote:Is this image displayed when the mouse pointer is placed in the name of a folder that contains subfolders?
Alright.Leito wrote:In a multi-screen environment, could you make it so that the whole HoverBox stays on the screen where the XYplorer window is? Currently the HoverBox steps over the other screen.
v19.20.0018 - 2018-10-09 14:30
* Hover Box: In a multi-screen environment the whole HoverBox now stays on
the screen where the XYplorer window is. Before it would sometimes step
I think there's a bug though : I have screen #2 set to the left of screen #1 (which is the main screen) :
Screen: 1920x1080, 2/2 (Secondary), Virtual: (-1920, 0) - (3840, 1080), Work: (0, 0) - (1920, 1040)
It only works for files, for folders I have to do some configuration?Leito wrote:Yes, called "Hover Box".CompSystems wrote:Is this image displayed when the mouse pointer is placed in the name of a folder that contains subfolders?
Configuration | Information | File Info Tips | Show Hover Box | Select Item Types...
v19.20.0019 - 2018-10-09 23:49
! Hover Box: Wrong initial placement of box since v19.20.0018. Fixed.
ok folder appears, although, should say "Folders and files"jupe wrote:Configuration | Information | File Info Tips | Show Hover Box | Select Item Types...
Ideas:
1: better two options only one to display folders and other folders and files
Configuration | Information | File Info Tips | Show Hover Box | Select Item Types... folders
Configuration | Information | File Info Tips | Show Hover Box | Select Item Types... folders and files
2: the icon that symbolizes the folders, should also be double, that is, an icon that only represents folders if the content contains only folders and a special icon that shows if it contains both folders and files
