HoverBox™
Re: HoverBox™
Ok good it's not just me. I was trying to figure out if my settings were messed up and was right clicking and holding furiously at the speed of light.
Anyway, awesome new feature!
By the way, how is the maximum size to display determined? It seems a bit random to me at the moment. Perhaps it's something that can be tweaked?
- Location: Hamburg, Germany - Win 10 Home v22H2 x64 1920x1080 (100%)
Re: HoverBox™
Before someone complains he won't see what everybody else is already enjoying.
Some hundred years ago i set this tweak and then forgot about using (the SHIFT key), because without saying there is a bunch of XYplorer ways to file info.
Set that back to zero and enjoy Hoverbox - the RSI antidot
; Tweak: set to 1 to show File Info Tips only if the Shift key is held
FileInfoTipHoldShift=1
Re: HoverBox™
- There is nothing to configure (I hope this feels relaxing to you).
for the moment i observe strange behavior.
- Large Icons, Small Tile, Large Tiles, Thumbnails view does not provide HoverBox when upon icon, only on name hover
and it's the same if "File Info Tips > Show info tips only when hovering file icon" is ON or OFF. smt here is definitely not as desired
Win 7 SP1 x64 100% 1366x768
Re: HoverBox™
It should be alright with v17.60.0106 - 2017-03-02 23:54.Enternal wrote:Ok good it's not just me. I was trying to figure out if my settings were messed up and was right clicking and holding furiously at the speed of light.
400 x 400 bounding box.
Re: HoverBox™
It is desired. Only a small area should be "hot" for info tips. Else in those views you would get tips popping up all the time.eil wrote:for the moment i observe strange behavior.
Re: HoverBox™
Good tip, I think I will raise it to GUI.Linkaday wrote:Before someone complains he won't see what everybody else is already enjoying.
Some hundred years ago i set this tweakand then forgot about using (the SHIFT key), because without saying there is a bunch of XYplorer ways to file info.Code: Select all
; Tweak: set to 1 to show File Info Tips only if the Shift key is held FileInfoTipHoldShift=1
Re: HoverBox™
i find it little not obvious for Large Icons, as others at least have thumbs seen, but this one stays with icons. though have no real complain, i use Large Icons close to none.admin wrote:It is desired. Only a small area should be "hot" for info tips. Else in those views you would get tips popping up all the time.
Re: HoverBox™
HoverBox is extremely hot&cool! almost horny.yusef88 wrote:true it does not workadmin wrote:So this program probably hooks into the File Info Tips, interesting. So it does not work if you untick "Configuration | File Info Tips | Show file info tips", right?
the program has a (No Install) version
Still, from that reply I thought that the HoverBox would be working independently from File Info Tips (admittedly a totally subjective assumtion). Not that it is a big problem but it would be nicer if I could have the HoverBox for images (only) and/but no file info tip for the other files at all. Or did I overlook something?
Re: HoverBox™
Correct, it's controlled by the master switch "Show file info tips".
Re: HoverBox™
Hi all
Nice one, but looks a bit weird on my dual screen setup. If the mouse is in the lower pane, the whole preview appears on the second screen.
Cheers
André
Cheers
André
Re: HoverBox™
I see the mouse: middle of the right screen.
Where it should be to show the box
W7(x64) SP1 German
( +WXP SP3 )
( +WXP SP3 )
Re: HoverBox™
Sorry, forgot to mark it. The left screen is the primary screen.admin wrote: Which is the primary screen, where is the mouse?
