Hi, I wanted to know if it is possible to change the color to the background of the tree view in XY from the .ini file.
Thank you.
Tree background color
- Immagine 2021-10-27 192012.png (43.52 KiB) Viewed 331 times
Re: Tree background color
Key: ClrBackTree
Section: [Settings]
Section: [Settings]
I had tried this setting, but it doesn't seem to work with my config file, moving it and restarting with the default .ini file all works correctly. Are there any other settings that may affect this problem?
