Scripting Memory-Leak / Speed Degrading
Re: Scripting Memory-Leak / Speed Degrading
Post by jupe » 24 Sep 2019 06:07
I am also having problems, after a while of dissecting some complicated scripts I have narrowed it down and created this example, if I load a script like this:
	$menu = <<<>>>
"Error" sub "T2";
"Test1 : T1"	status 1;
"_Test2 : T2"	status 2;
	load $menu,, "s";
And click on the first item "Error", I get an error "no matching labels", but if the same $menu is in a normal file.xys no error is generated, there have been no problems in the past with this implementation.
Post by admin » 24 Sep 2019 09:08
Oh yes, that's since 20190919. Fix comes.
FAQ | XY News RSS | XY Twitter | Stay home! 🎸 Wear DIY masks! 😷
Post by Filehero » 30 Oct 2019 13:06
Hi Don,
unfortunately, my issue is still (again?) there (breaking nearly the half of my existing scripts). To make it easier I re-copy the script example already posted.
Base script:
include_once "testLib.xys";
// call lib function
  callTest();
// build in-the-fly script code
  $mscript = <<<SCRIPT
include_once "testLib.xys"; // <-- INDENTING THIS STATEMENT EVOKES ERROR AGAIN -->
  callTest(); // <-- THIS IS WHAT SHOULD WORK AFTER ALL -->
SCRIPT;
  // NOW THE ERROR GETS THROWN HERE - this logic has been working for years
  load($mscript, , "s");
base.7z
(416 Bytes) Downloaded 45 times
Referenced script:
testLib.xys
(95 Bytes) Downloaded 46 times
Broken behavior: callTest() is called only once (when the call is done from the base script)
Expected behavior: callTest() is also called from the inline-assembled script run by load()
Note: both includes are done using include_once.
Control: version 20.40.003 is working fine (with include as well as include_once).
Post by Filehero » 30 Oct 2019 13:08
Hmm, a single-clicked bump isn't ery nice.
Humble bump. :wink:
Post by admin » 30 Oct 2019 14:34
This is what it's about here?
Post by Filehero » 30 Oct 2019 15:26
No, sorry - I should have deleted that old comment the before doing the copy.
This time I haven't found any possible cause (indentination hadn't any influence afair), the (2nd) call ofcallTest() referenced from the inline-assembled script simply doesn't happen.
30 Oct 2019 14:34
Post by admin » 01 Nov 2019 12:26
OK, saw it and fixed it. Next beta. What a can of worms... :cup:
Post by Filehero » 01 Nov 2019 18:18
First quick check - the finish is much brighter now.
Re-test with my test scripts: [x]
Re-test with my critical scripts: [x]
:beer: :now: :red: :wine: :for: :celebration:
v20.50.0107 - 2019-11-01 13:46
    ! Scripting: The fix (from v20.40.0005) concerning repeatedly loading the
      same resource file needed some more polishing. Polished again.
Has the original "improvements" been completely rolled-back now code-wise?
Btw, to me it was really irritating that no one else has been complaining, I thought repeatedly loading the same resource file is used much more by others.
Anyway, thanks heaps!!!!!
Post by admin » 01 Nov 2019 19:19
Filehero wrote:
01 Nov 2019 18:18
Nope, I just polished it. :)
