Sometimes URL don't connect but IP works fine
Re: Sometimes URL don't connect but IP works fine
I believe it did in Windows Explorer but that only happens very rarely.
Most of the time windows explorer can access the network drive either with the IP or URL w/o password prompt.
1) I meant in XYplorer, does the IP path pop a logon prompt in XYplorer?
2) Please run this script through the XYplorer address bar and post the result or just tell: is the unavailable server listed in the result?
text runret("net view");
The IP path works w/o prompting for a P (although it might be because the PW was entered in Windows Explorer)
System error 6118 has occurred.
The list of servers for this workgroup is not currently available
OK, that helped. Might be fixed in next beta.
Happy to test out a beta if you'd like,
You can test the beta now.
Where do I find the Beta?
Sorry to tell you the problem still exists.
Right after you get "Location currently not available" run this script, please...
... and post a screenshot of the return window that pops up.
- 2019-08-28_5-48-52.jpg (168.17 KiB) Viewed 1182 times
When you run this script (replace [yourpath] with your path), what is returned?
exist "[yourpath]";
Exist
H:\0 ClipArt\(\Seagate-437403\Public\Videos\TV A-B)
According to XYplorer 20.30.0009 on 2019-08-28 08:34:17,
does "H:\0 ClipArt\(\Seagate-437403\Public\Videos\TV A-B)" really exist?
ExistFile: False
ExistPath: False
ExistFolder: False
ExistItemFF: False
ExistPathFF: False
ExistPathOrFile: False
ExistPathOrFileShell: False
ExistIcon: False
IsNetworkLocation: False
GetDriveType: 3 (DRIVE_FIXED)
GetItemType: 10
GetFileAttributes: 0xFFFFFFFF (-1)
Owner:
Watchable: True
FilenamesCaseSensitive: False
ExistFile: False
ExistPath: False
ExistFolder: False
ExistItemFF: False
ExistPathFF: False
ExistIcon: False
GetItemType: 10
Owner:
Watchable: True
- 2019-08-28_8-28-55.jpg (100.44 KiB) Viewed 1173 times
When I execute Exist "(yourpath)" it's prefixing it with the path I'm in at the time.
My path is \Seagate-437403\Public\Videos\TV A-B
What should the actual script be?
