Prompting user not working ?
PeterH
Re: Prompting user not working ?
Post by PeterH »
You should count parameters from left, not from right (i.e. "the last").
Win11 Pro 223H2 Gerrman
CookieMonster
Post by CookieMonster »
Parameter two is optional, although not giving a parameter causes it to not work, therefore can I skip parameter two ?
PeterH
Post by PeterH »
CookieMonster wrote:Parameter two is optional, although not giving a parameter causes it to not work, therefore can I skip parameter two ?
This would mean that parameter 2 is parameter 3 :shock:
Would you understand what is meant?
CookieMonster
If parameter 2 is optional, then how can you bypass this parameter ?
Post by RalphM »
Have a look at the last example for confirm() in the help which shows how to skip "unneeded" parameters and adapt it to your needs.
If that's too much to ask then you should probably stay away from scripting. :whistle:
Ralph :)
(OS: W11 22H2 Home x64 - XY: Current beta - Office 2019 32-bit - Display: 1920x1080 @ 125%)
