F5 pressing when in search result panel
Posted: 26 Aug 2004 11:58
by Leopoldus
When I press the key F5 in search result panel, the panel changes to one of folders on the current drive (every time this is the same folder with name H:\! . Could you explain, what should happens accoring to your idea?
Re: F5 pressing when in search result panel
Posted: 26 Aug 2004 12:14
Leopoldus wrote:When I press the key F5 in search result panel, the panel changes to one of folders on the current drive (every time this is the same folder with name H:\! . Could you explain, what should happens accoring to your idea?
F5 refreshes the folder currently selected in tree. To refresh find results press F3.
Posted: 26 Aug 2004 12:55
by Leopoldus
In my system this is not so. Now I see, that this is not a problem of search result panel, but the general one. No matter which folder or drive is current (or was cuurent before searching), after pressing F5 the current folder always changes to
H:\! . I have no any ideas
(( Have you?
Posted: 26 Aug 2004 13:00
Leopoldus wrote:No matter which folder or drive is current (or was cuurent before searching), after pressing F5 the current folder always changes to H:\!
That's crazy! The current folder is also displayed in the title bar of the window. Is that H:\, too??
Posted: 26 Aug 2004 14:27
by Leopoldus
No, in title bar I see the same folder's name as in the tree panel.
This is, in the tree panel the current folder is C:\ABC, in the title bar the same, and in files panel I see the content of it. OK. Now I press F5, and what is the result? The situation in the tree panel and in the title bar has not changed, but in the file panel I see now the content of another folder, this H:\!, is it would be the content of C:\ABC.
Total mystery, isn't it?!
Posted: 26 Aug 2004 14:35
Do you have a drive H:\?
If yes, anything special about that drive?
Did you try to close and restart the app?
Posted: 26 Aug 2004 14:53
by Leopoldus
Resrarted the app now. The problem's gone away!!
P.S.
But mistery however was indeed. (By the way, I have H: drive, it is a very usual virtual volume, and folder H:\! does exist too.)
Posted: 26 Aug 2004 14:59
Well, good it's gone! Whenever you manage to reproduce this, let me know.
Don
Posted: 26 Aug 2004 15:14
by Leopoldus
Surely! But for now - many thanks for wise advice!
