No Tree anymore (22.30.0206)
autocart
Re: No Tree anymore (22.30.0206)
Post by autocart »
autocart wrote: 23 Oct 2021 22:57 EDIT:
Ok, more tree problems with 20.30.0206, following these steps:
  1. fresh;
  2. Config | General | Tree and List | Show Network folder -> OFF (and OK the config dialog)
  3. Navigate in the tree to, as it seems, any subfolder of "C:\", e.g. "C:\Users\Public" or "C:\Program Files".
  4. Activate the Mini Tree -->> BIG BADA BUMM!!!
    With, e.g. Program Files the tree jumps back to "Dieser PC", which it should not, but the problem becomes more visible when naviagting back to Program Files again. With the Users\Public path it should be super visible immediately -> Path all of a sudden not available. If navigating back to Users, it is Network instead. Tree path tracing becomes wacky too.
If necessary I can make a screen recording.
(And loadtree in a location change CEA is making XY recursive again, as it seems, when a full "C:\bla bla\..." path is included, but that might be related to the problems above.)
This seems to be solved in 0207.
Tree is back. I'm not quite shure about locking, but will have a deeper look tomorrow.
Edit: tree locking via the menu works, the root node needs to be selected (doesn't remember how it's used to be).
Evolve
Post by Evolve »
My Locked Mini Tree works great. I don't see no bugs.
jupe wrote: 24 Oct 2021 10:35 It might even of been worth it, if there was going to be a benefit to users in the end.
I haven't been elected to represent all the users, but for at least one of them i.e. myself, this is extremely beneficial. I feel bad for all the troubles though.
autocart
Post by autocart »
Evolve wrote: 25 Oct 2021 13:09 I feel bad for all the troubles though.
Don't worry. These in between updates are beta versions. This is the usual procedure.
