Tabsets: Can't revert to saved
cadu
Re: Tabsets: Can't revert to saved
Post by cadu »
2) After "Revert to Saved", can you still use those tabs (or are they just ghosts due to a drawing glitch)?
The tabs are fully usable after the unsuccessful operation. The only issue is indeed they are not reverting.
Thanks for the assistance!
BobCrash
Post by BobCrash »
Hello, I also had a similar prob with the tabsets not reverting or even loading different sets ... just nothing going on.
Was in v19.20, but with 19.30, all seems well. I've been using an older ver of session manager, and had the odd named saves popping up in the dialog boxes, but can't say that had anything to do with it.. Didn't look too far, and now all seems ok.
cadu wrote: 23 Oct 2018 12:40
Well, this is a total mystery to me. Sorry, but I'm out of ideas. :(
cadu
Post by cadu »
admin wrote: 03 Nov 2018 10:06
The problem XYplorer can't revert tabset to saved is still happening, even in v.19.60 (below the debug log ran after unsuccessful trying to revert).
Besides deleting the folder "XYPlorer\Data\Panes", could try to force "tabset reverting" by changing/removing content from "XYplorer.ini"?
I think the problem is in "XYplorer.ini", because when I try a fresh XYplorer install the "tabset reverting" is working. However, if I replace the fresh "XYplorer.ini" with the old (my current) "XYplorer.ini", the problem reappears. So it seems something in the "XYplorer.ini" is causing the issue.
Thanks for assistance!
Debug Log
XYplorer 19.60.0000  -  Windows 10 Professional, 64-bit, Release 1803, Build 17134.523  -  2019-02-12 14:00:09.594
2019-02-12 11:37:11.821 >> WM_SETTINGCHANGE: monitors changed, 47, 0
2019-02-12 11:37:17.167 >> WM_SETTINGCHANGE: monitors changed, 47, 0
Post by bdeshi »
This is the cause of the bug: Main Menu > Tools > Configuration > Tabs > Auto-save tabsets on switch
When this setting is enabled, tabset changes are apparently saved instantly, instead of on switching tabsets.
Here some :beer: :beer: :beer: :beer: :beer: for Sammay! Drink responsibly. :tup:
yuyu
Post by yuyu »
SammaySarkar wrote: 13 Feb 2019 06:10 This is the cause of the bug: Main Menu > Tools > Configuration > Tabs > Auto-save tabsets on switch
Great! That was there everlasting and that is why I was always distracted from "Tabsets". Thought that was a feature))
cadu
Post by cadu »
Problem solved.
Thank you very much SammaySarkar!!!
