Humf ... For my own, I run W10 build 14393 and XY 14.30. And everything is OK.
I'm sure someones run :
- W10 build 14393 + XY 17.40, or
- W10 build 15007 + XY 17.30
It will be great sharing your experience ...
XYplorer 17.40
Re: XYplorer 17.40
Hmm, there no problem with XY on Win10. What makes you think so?
Re: XYplorer 17.40
You're right, there is no problem with W10 b14393 and XY 17.30. But Price's post give a doubt : he reports a problem with W10 b15007 + XY 17.40. Due to 15007 ? Due 17.40 ? Maybe both ? Maybe specific to Price's other config ? I don't know.
So, I plan to upgrade my b14393/17.30 to b15007/17.40 (as Price did !) in the next days but I'am lazy and I would prefer avoiding a rollback
This is the reason while I think a cross test will give some informations.
Re: XYplorer 17.40
Sorry. Please read 17.30 and 17.40 instead of 14.30 and 14.40 in my posts.
Re: XYplorer 17.40
I've edited your posts to reflect that "change" to avoid more confusion (on my side)^^
Re: XYplorer 17.40
@highend, while your confusion has been remedied by editing that post you have to agree that your question about 14.40 might now confusing everybody else, don't you think?
Ralph
(OS: W11 22H2 Home x64 - XY: Current beta - Office 2019 32-bit - Display: 1920x1080 @ 125%)
Re: XYplorer 17.40
That problem was not any incompatibility between versions, but a simple Windows hickup. This is pretty normal for OSs to happen from time to time and can usually be cured by a restart or a relog (log out/log in) (as in this case).Asta wrote:You're right, there is no problem with W10 b14393 and XY 17.30. But Price's post give a doubt : he reports a problem with W10 b15007 + XY 17.40. Due to 15007 ? Due 17.40 ? Maybe both ? Maybe specific to Price's other config ? I don't know.
Re: XYplorer 17.40
With release 17.50 I get the same error. I am using Windows 10 build 15014 it seems to not come with VB 6 Runtime. Si I installed parts of this program
and it works. Not sure if MS will install this in The Creators Update which is due for release in April. Just an FYI
Visual Basic 6.0 Runtime Plus 2.2.zip
