reset ntfs partition permissions
What other productivity software are you working with...
Re: reset ntfs partition permissions
You did read the comments in the script?
    // Edit this list if you want to add / remove commands to process
    // Ofc you need to add additional variables right over this comment...
Not the script failed, ICACLS failed.
<- On vacation for a week
highend wrote:<- On vacation for a week
Have lots of fun and enjoy it. :D
yusef88
Post by yusef88 »
highend wrote:You did read the comments in the script?
Of course, the script is flawless ،i'm also going on a long vacation ..thanks an bye
Post by bdeshi »
You're all going on vacation; my vacation is almost over!! :o
Well, have a great time!
CookieMonster
Post by CookieMonster »
All these scripts reset NTFS partition permission; none will temporarily give a folder, like Program Files folder, elevated rights then via a timer or another toggle reset the permissions back to preventing the user from writing to the folder, if one only needs the elevated rights for a few minutes or maybe a few hours ?
And? The thread is called "reset ntfs partition permissions" not "do something else"...
Write your own script that does what you need^^
CookieMonster
highend wrote:And? The thread is called "reset ntfs partition permissions" not "do something else"...
I know. :|
I want to get a sense as to what in particular the scripts in this thread are doing, is there something wrong with that ? Did I commit a felony ?
Read the docs about icacls?
CookieMonster
If one wanted to give full rights to the folder, program files ?
icacls c:\program files\ /T F
Basically you can tie the command to a script to toggle which options on a button ?
1. No and you obviously didn't read icacls docs
2. That command "directly"? No. And what the button does (and the script that is assigned to it) is up to you...
CookieMonster
I read these docs (http://www.computerhope.com/icacls.htm). I wanted to know if the command I posted would apply full access to the folder I applied the command too; including sub-folders ?
Nope
CookieMonster
highend wrote:Nope
Well, what would be the correct command ?
That's easy...
Command: *Read the docs*
