BETA version (with detailed history information)
Get a glimpse of the next XYplorer...
Locked
Re: Here's the new BETA
Download the latest TrackerV3 BETA version (v4.00.0009, 06-apr-2005).
  +++ major new feature
    + new feature
    * changed feature
    % improved performance
    ! fixed minor bug
  !!! fixed major bug
v4.00.0009 - 06.04.05 13:28
    + Tab Strips coloring: no more INI-editing (cf. v3.60.0029). Now all
      tab strips take the same color scheme as user-defined in
      Configuration/Colors (F9).
    + Toolbar can be hidden now: menu View/Show Toolbar.
    - Shortcut removal/replacement! These commands are not frequent
      enough to merit one of those rare delicious shortcuts (for which I
      have other plans deep in my mind...):
      Menu Edit/Show Folder Sizes -> no shortcut anymore (was Shift+F5)
      Menu Edit/Refresh Thumbs Cache -> now Ctrl+Shift+F8 (was Ctrl+F5)
    * Moved the Refresh commands from the Edit to the View menu.
    + Auto-refresh of file list now is blocked while you are renaming a
      file.
    + Double-clicking the splitters does minimize/maximize them again ;)
Chris Wood
Post by Chris Wood »
Wow, three problems I had fixed within a day of requesting them!! Thankyou! :D
Chris Wood wrote:What *was* "Automatic File Find when Browsing"?
Check the help file...
Duh, sorry :oops:
Hmm, it's still there (in the help file) :P
test everything. hold on to the good.
Chris Wood wrote:Hmm, it's still there (in the help file) :P
Ahhh, the help file... every programmer's nightmare. I always update it before I release an official version. Which will be soon... sigh
Download the latest TrackerV3 BETA version (v4.00.0010, 07-apr-2005).
    + new feature
    * changed feature
    ! fixed minor bug
  !!! fixed major bug
v4.00.0010 - 07.04.05 13:27
    + Now each tab can have its own "Home", defined by a browse/find
      location and mode, and the usual list settings.
      - To set (or update) the current tab's home click "Set Home"
        (menu View/Browsing Tabs).
      - To go to the current tab's home click "Go Home"
        (menu View/Browsing Tabs) or simply press F6.
      - You cannot unset a home because it's not necessary
        (if you don't want a home, don't go home).
      Homes are remembered between sessions, and can be set
      independently of the tab being named or not.
      A new tab starts homeless.
      Apart from the possibility to click "Set Home" home tabs behave
      100% like homeless tabs.
Download the latest TrackerV3 BETA version (v4.00.0012, 07-apr-2005).
    + new feature
    * changed feature
    ! fixed minor bug
  !!! fixed major bug
v4.00.0012 - 07.04.05 21:03
    + Toolbar: added Home icon. Click to go to the current tab's home.
      The tooltip shows where home is.
    + Now "File Info Tips" (hovering over file icon in file list) show
      the path of the file if in Find mode (Win2K and WinXP only).
    * "Keep Particular Characters..." and "Search and Replace..." (menu
      File/Rename Special) now do not change the extension (incl. the
      dot) but just the file title (or base), that's everything but the
      extension.
Download the latest TrackerV3 BETA version (v4.00.0016, 08-apr-2005).
    + new feature
    * changed feature
    ! fixed minor bug
  !!! fixed major bug
v4.00.0016 - 08.04.05 13:39
    + Added "RegExp Rename..." to Rename Special (menu File) which
      allows you to rename selected filename(s) using Regular Expressions.
      Format: RegExpPattern > ReplaceWith
          or: RegExpPattern>ReplaceWith
      The default is case-insensitive (a=A). To search case-sensitively
      add a back-slash to the end of ReplaceWith:
              RegExpPattern>ReplaceWith\
      Examples:
      .html$>.htm = change extensions .html to .htm
      .html$>.htm\ = change extensions .html (but not eg .HTML) to .htm
Download the latest TrackerV3 BETA version (v4.00.0020, 10-apr-2005).
    + new feature
    * changed feature
    ! fixed minor bug
  !!! fixed major bug
v4.00.0020 - 10.04.05 14:04
    - Feature Reduction: removed Copy Path, Copy Folder Name, Full
      Collapse, Full Expand from menu Edit. Those commands are still
      available in the tree context menu.
    + Tabs: if a browse target or find location is not found (eg
      because it's currently not accessible or has been renamed) on tab
      selection, a warning message is displayed giving you the option to
      not open the tab.
Download the latest TrackerV3 BETA version (v4.00.0025, 12-apr-2005).
    + new feature
    * changed feature
    ! fixed minor bug
  !!! fixed major bug
v4.00.0025 - 12.04.05 11:25
    + Tabs pointing to shared resources are checked for availability at
      startup. If not available, they'll have no icon.
    ! Tooltip of Home icon was not always correct on a tab in find mode.
      Fixed.
    ! Tabs: a crash could be generated when a browse target didn't exist
      anymore on tab select and the target's parent had a new child folder
      at the same time. Fixed.
    * Find Files, Name/Location combos: auto-completion revised.
Download the latest TrackerV3 BETA version (v4.00.0027, 13-apr-2005).
    + new feature
    * changed feature
    ! fixed minor bug
  !!! fixed major bug
v4.00.0027 - 13.04.05 11:18
    * New command "Load Configuration..." in menu File. Loads a
      previously saved (Save Configuration As...) Configuration (INI file).
      Tip: in the title bar of the configuration window (F9) you can see
      the currently active INI file.
    ! Hung on select tab when drive was not available. Fixed.
Download the latest TrackerV3 BETA version (v4.00.0033, 14-apr-2005).
    + new feature
    * changed feature
    ! fixed minor bug
  !!! fixed major bug
v4.00.0030 - 14.04.05 15:55
    + If start path is currently not available you now get a message
      with a yes/no-choice:
      Yes: browse to the next available parent path.
      No: keep the currently unavailable tab and its settings, and
        browse to the next available parent path in an automatically
        created new tab.
    ! Crashed when selecting a tab pointing to a nethood server after
      switching Show Floppy Drives on and off. Fixed.
Download the latest TrackerV3 BETA version (v4.00.0035, 15-apr-2005).
    + new feature
    * changed feature
    ! fixed minor bug
  !!! fixed major bug
v4.00.0035 - 15.04.05 14:22
    * Report, Classic directory dump: revision! Now you can set the
      table width in Configuration (F9), Report tab, "Classic directory
      dump table width". And you can decide about wrapping lines via
      the checkbox "Line feed on oversized filenames".
    * Report, Extended info to CSV: the list separator is now taken from
      the OS regional settings. Before it was hard-coded to ",".
Download the latest TrackerV3 BETA version (v4.00.0039, 16-apr-2005).
    + new feature
    * changed feature
    ! fixed minor bug
  !!! fixed major bug
v4.00.0039 - 16.04.05 18:47
    * Revision of handling of unavailable paths: no more message boxes,
      but simply a greyed out file list. Just select any tree folder
      to put the tab back to real life (or leave it in ghost state until
      its target is available again).
    ! Crashed on huge file copy jobs due to some experimental change in
      v4.00.0016. Fixed by removing the experiment. I told you it's
      BETA, didn't I?
free
few bugs...
Post by free »
Been a silent fan for a while but this prompted me to post... :twisted:
As soon as I loaded the latest beta, the %profile%\history folder
and sunfolders are no longer available!
-Removed entire tracker,ini, even the find file templates.dat -- no go!
Removed beta, applied 'release', History folders are available!
Exact msg is:
'curently not available:'
..'Docs n settings'\*user*\local settings\history\history.ie5\<path to subfolders'
-Speaking of path and %profile%:
Long time bug that accompanied all prev and current beta/releases.
-Favorites>special folders>temp folder
Always defaults to my current drive! it does not find the sys temp or the profile temp!
Reason is likely to be.. this is partitioned while logged into "d:"(winxp)
And "c:" (WinME) but D: is a logical drive in an extended partition!
A while ago on another computer it behaved the same..
While dual-booting to D:/win2K(c/win98) top menu temp pointed the drive itself(d:) to be temp folder.
It is definitely NOT using the standard PATH statement in env variables
but somehow looking at the drive structure differently.
free
Post by free »
Quick addition:
If logged to main partition C:. the 'temp' bug does not apply.
The favorites menu finds it.
However another dirive letter seems to be the trouble.
I'm not sure if it's only applicable to extended partitions or anything other than C: ??
(All other special folders are being recognised just fine!?)
As for the 'history' bug, it's definitely in 'v4.00.0039'--
Just reproduced it on C: as well.
P.S:
While trying to figure out the 'history' enigma from D:
Tracker started pointing out more dirs as 'currently not available'.
Ended up flagging "MyComputer" as not available :?
..And --crashed..
Faulting application trackerv3.exe, version 4.0.0.39,
faulting module oleaut32.dll, version 5.1.2600.2180,
fault address 0x00004874
Re: few bugs...
Thanks for breaking your silence!
The history folder will be back in the next BETA, and the TEMP folder will be the right one, too.
Locked
